Heat/a/c
budget95
Mass.
I'm have an issue with the heat staying on when a/c is on! Doesn't happen all the time. It's like every other time I want to use it. When I turn it on and it works properly it's plenty cold!
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Manual or Automatic HVAC?
You mean you set it to "cold" and it blows warm air, or you set it to "cold" and it blasts like a furnace?
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
What does the display show? Specified temp? Is the A/C indicator on? Does it come from the appropriate registers? What if you turn it off and back on? I've had mine just not do anything, hit the OFF button, then back to A/C and it works fine.
Sounds as if you HVAC control unit (The display and controls in the dash) is starting to fail. Before you ask, no you can't just switch it to manual controls. The entire system needs to be changed, not just the control panel (like remove the dash and change all the HVAC stuff inside the dash,)
budget95
Mass.
I'll put it to 60. Indicator on and appropriate register. Turn off and on several times with no luck. Then the next day work fine.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
On most "modern" vehicles (at least since the late 70's) there is a box in the back of the engine compartment/behind the dash with 2 compartments. One contains the heater core, one contains the evaporator. The coolant is ALWAYS running through the heater core, as long as the engine is running, unless there is a divert-er valve in the system) The outside air enters the "un-conditioned" side of the box, there is a blend door that is used to direct the air to the heater core, and/or the evaporator core. In a manual system, this is controlled by either a cable (some of the older trucks are this way) and most now are controlled by vacuum (the hiss you hear when you change the temp, or the register (floor, vent, defrost) when the vehicle is not running. The automatic systems are similar but the HVAC control unit controls the vacuum motors, rather than the position of the knob.
Now, on yours, if the control unit is commanding the blend door to stay at 50% equally hot and cold, or the blend door is broken, stuck, missing, bad seal, abducted by aliens...... whatever. The selected temp may read 60 (which if I remember how mine works, it's not my daily driver) 60 is the same as Max, High Fan in a manual system (penguin mode, they way I keep my P71). So the HVAC unit is trying to freeze you out. But, if the blend door can't blend for what ever reason, the fan will be running "balls to the wall" trying to bring the temperature down to 60. But in this situation, the heater would also be running wide open. In just about every case, heat will win over cold. You live in the North, you can heat a room with a 1500 watt (5100 BTU) heater, but it takes a 8000 BTU to A/C to try to cool the same room.
So with the current weather (Here in Central Indiana, we've been running almost 90 with high humidity) you have a little cool, being overrun by 200 degree heater water, along with the 90 degree ambient temperature, the heat is going to win. I would look into the operation of the blend door. There is a laundry list of things that can cause issue (like listed above) or even a pen/pencil that's fallen through the defroster registers........ When it works, maybe you've hit a bump and the pen moved, and wala.... blend door works, then it moves again and cause a jam, or a split vacuum line, or the electronics have gone haywire..... time to start some detective work. You may be able to remove the fan from HVAC Box under the hood and see inside the box........
budget95
Mass.
Good point. I was just talking to a co worker he said the blend door actuators go frequently. I'll check it out tomorrow.
Thanks for the help guys.
IDIBronco86
