I just had to do this on my 93. To adjust the up and down you used the rod that sticks up out of the header panel right?
I cant remember right now but i read somewhere(maybe haynes manual) that to adjust the left to right you have to remove the plastic bezel and use the screws that are on the mounts where the lights attach to the header panel. I cant remember which screw you adjust for the left to right though. Ill read it up in haynes when i get home unless someone else comes along.
