G. Mann
Since I just received my box of ARP studs with instruction sheet, I'll chime in.
it says:
Note: ARP Ultra-Torque Fastener Assembly Lubricant has been specifically designed to reduce tension preload scatter and eliminate the need to cycle high performance engine fasteners before final installation. ARP Ultra-Torque far surpasses all requirements offered by previous AR lubricants in terms of fastener preload repeatability and performance lubricating properties. For more information on ARP Ultra-Torque visit our website at www.arp-bolts.com or call 1-800-826-3045.
I'm betting a phone call would get them to ship you some of this magic juice. As I understand it.. the Ultra Torque is applied to the nuts and washers, not the part of the stud that screws into the block? Guess I need to make a phone call on Monday to sort that out exactly...
On jet engines I used to build, we used a hydraulic ram to actually pull the main center bolt and then measured the stretch with very precise dial gage. When bolt stretch was at the right amount, the nut was then hand tightened and hydraulic pressure released... [That one bolt costs about $8,000] but it held all the compressor wheels stacked together.
With the ARP studs we are using the nut to stretch the bolt via the threads, which are mechanically a ramp.. so we need to "lube the ramp".
it says:
