73idi88f350
so my truck has gotten harder and harder to start to the point ive had to hit it with ether for a few days in the am to get it to fire.. the wait to start light sometimes will stay on for a while sometimes it will flicker.. ive also check it while cranking and it also flickers and stays off sometimes.. so im thinking i got a bad connection somewhere in the glow plug system.. it is on a Manuel switch but only to bypass the key on and off part.. so i could turn them on and off when i wanted...
so if i hit it with a small spray of ether and jump the starter solenoid it will fire and keep running so i should assume i have no fuel issues right? seems as if the glow plugs become no help in starting.. i do know what to look into to fix my issue just wanna be sure im not starting in the wrong direction
thanks!
thanks!
