Hard Starting
osus86diesel
Troy, Ohio
just got back from a weekend at the farm... and things aren't looking any better with the old beast. I tightened all the fuel lines at the filter and none of my injectors look like they are leaking.
Could my lift pump be bad? or is there some other things i could check first?
LCAM-01XA
my very own hell
Time to crawl under truck with an LED flashlight and start examining the fuel lines - start from the fuel filter and work your way back to the tank selector valve. Check the fittings at the lift pump, the hose between the lift pump and the steel line on the frame, and the steel line under the engine and then plastic line connection insider the frame rail.
zpd307
Zumbrota, MN
i still dont think it is so much of an air leak problem. when it is running, check for psi and volume to rule out lift pump.
Sounds like a worn IP to me, or no glow plugs.
zpd307
Zumbrota, MN
mine started like that today. it was 35 degrees, not plugged in, and hadnt been run since saturday. does it start that way even without it being plugged in.
Vinceslamer
