mooseracing
I just picked up a '94 F350 with a IDI 7.3 non turbo. Has about 165k miles on the clock, runs good, at least to me.
This is my first venture out of the gasahol world. I'm having some issues with cold engine starts. It doesn't matter if it is 50F up to currently 80F.
When Key On Engine Off, the WTS light is on 5-10 seconds, then I crank 5-10 seconds which it acts like it wants to fire or it does fire then dies. Then usually the second try it starts up and idles a little low than kicks up to the higher idle. It also emits the blacker smoke during this time and also black smoke when driving until the engine starts to warm up. It also seems to not want to get above 45mph or so during that time, kinda chugging along.
Once warm there is no smoke and it runs great down the road. 90% of the time it fires up right away as well.
I was planning on changing the fuel filter tonight, since I don't know when that was last done and also changing transmission fluid and filter. Also picking up the SCA filter kit setup from NAPA. What else should I be looking at for my issues on the cold running?
Thanks
Thanks
