Gutting CDR valve?
FoolhardyIDI
Arizona
Just installed a Banks Sidewinder turbo on the truck. I remember a while ago someone mentioning that they gutted there CDR valve. Good or bad idea/ Or just make a road draft tube?
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Why gut it? The only thing it does is prevent a run away engine IF the air intake is restricted. If the air filter or intake system is severely restricted the CDR closes to prevent the engine from sucking oil from the crankcase through the vent and running away until it blows from uncontrolled rpm or seizes because there is no oil left in the pan. It had a diaphragm and a spring. Only possible failure is a ruptured diaphragm which will allow oil to drop out the small hole in the cab. No black magic here.
FoolhardyIDI
Arizona
This is why I asked it as a question. I do not know the exact purpose of the CDR valve. Seams to be like a PCV valve on a gas engine to me. Only use is for PCV is emission. re-burn blowby.
Selahdoor
Index Wa
That's pretty much it.
I'd do the road draft tube.
kuskoal
Yokosuka, Japan
The CDR is a failsafe that shuts crank case vapors from the intake when it runs away, so to me it's pretty important to keep.
Road draft tube would work, but I would recommend a catch can instead! The blowby smell gets annoying after a while in traffic. Besides, a little more top end cylinder lubricant doesn't hurt :)
FoolhardyIDI
Arizona
So I decided to keep the CDR valve. Bought a new one to install with the Turbo. Thank you for your input.
Oh I am. I see several a year come through my boss's shop and most leak some oil. It's rare that he buys older than 2006.
raydav
Apple Valley, CA
That CDR is the only way for blow-by to get out of the crankcase. The blow-by gets pulled into the intake. With a turbo there is usually at least some positive pressure in the intake, and no gas being pulled from the crankcase.
The valley gasket I used came with a CDR port plug. I added vents to the valve covers and a Mann separator. I have a catch can for the oil and the gas outlet can go to the air intake, the exhaust pipe or a draft tube.
Scan down this album to see the evolution of mine.
https://goo.gl/photos/LJNV4esgmYmSzKdL8
m2rtin
