MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,639
- Reaction score
- 38
I need to cut extra threads on the unthreaded shank of two coarse 7/16 Grade-8 bolts, reason being I need two axle-flange studs, such that a nut will tighten against the axle-flange, and then a second nut holds the bracket for the Veederoot hubometer.
Can I cut these threads with my plain old run-of-the-mill thread-die kit, or will the material be too hard ??
What if I make these two studs from regular grade bolts, seeing as how the other six will still be the good stuff ??
Opinions and advice please.
Thanks.
Thanks.
