Glow Plugs
BlueCrew
ky
Im in need of new glow plug Whats out there I have Motorcraft ZD9 in right now but there rather exspensive Been thinking about something off ebay as long as the tip wont swell
Running anything but Motorcraft Beru ZD9 glow plugs is taking a big risk of failure. A tip breaking off can ruin an engine. At the very least it ruins a piston. If you have a turbo it will destroy the hot side wheel. So now how expensive does a set of Berus look. If you don't have the money to pay for Berus you can disable the glow plug controller and use ether to start the engine without any issues but you need to nkow how to use it. A less than 1 second burst is all thats needed into the intake path. Then crank for about 5 seconds. Do it again if its not starting. Never wet the intake with ether. Ether done correctly is harmless. done wrong its crack in a can and will kill an engine.
I just bought a couple of ZD1A's for my 6.9 at O'reilly's. They were $11 plus tax each. ZD9's are probably close in price.
RangerDanger
