Goofyexponent
Mentally Unstable..
Remove this diagram, it is not correct - your first one was the correct one. Also, on both diagrams you forgot one wire - it's a red/green wire that connects to the same terminal of the relay as the red/green wire you already have on the diagrams, but its other end is inside the controller - this wire is what turns the controller on when ignition is turned on.
Gotcha. I will update for the red/green wire as well. I thought something looked wrong with my second pic as it was a closed system...with no keyed input.
