ok so i been trying to figure out why zd9s keep blowing out in the diesel and someone mentioned timing. advanced timing will kill gps. but can retarded do this too? my pump is retarded a good bit from base (i think it has loosened up and pulled back gradually over time) anyone know if too little timing will kill a glow plug?
because if it is not timing then it is a 12v source direct but im adding the stock controller back in and want to know if this will fix everything before shelling out more money for plugs again. also it is retarded smokes whitish grey not black so that is a key for not enough fuel that i know.
