Does anyone have any schematics of how to build your own glow plug wiring? I could take my own apart. But if someone has already done the work I would like to reap the benefits. Thank you in advance.
may want to think about changing location of the controller.
the N/A's and some of the turbo models had the GPM on the rear of the engine.
kind of a PITA to swap out when you have to.
i swapped from the 6.9 NA to the 94 7.3 ATS, which put the module on the passenger side valve cover.
makes it a bit easier.
