I agree with you guys on the fact that a good working glow plug controller is better than a push-button set up. I went that route because I wasn't going to shell out 100 bucks for a new controller. Yes the 6.9 GP controller sucks, the 7.3 system is much better.
I have a donor truck with a 7.3 and ZF-5 speed waiting to get stuffed in my truck. When my 6.9 finally sings it's last song, I'll pull it and put the 7.3 + ZF-5 speed in.
But on a different note, I haven't used my glow plugs in over a year. They have no affect on starting my truck. Even after I replaced them, and verified that they are working. I think my IP is to tired and doesn't throw out enough fuel, or something. Every time I need to start my truck, I give a small shot of ether to the air cleaner, but thats only on the first start of the day. After the truck has run for a 1/2 hour or more, it'll start every time after that without problem, all day long. I know most of you reading this post are thinking, this guy's an idiot spraying ether down the throat of that poor IDI. If WD-40 was enough to do the trick I'd use it instead of ether.
But like I said, I have a 7.3 just waiting to get inside the old truck, which is going to go in this summer regardless if my 6.9 goes south or not.
