mjs2011
exactly the reason you should have to open the hood and use a push button switch to cycle your GP instead of this...
I have not used my GP in over a year, I plug it in instead, she is plugged in right now, No broken GPs
There are some areas of the country that get well below freezing on a regular basis and plugging in the block heater will do absolutely nothing. Either the glow plugs work, or you use ether, plain and simple. It doesn't matter if the block is plugged in.
