fiverpuller
Lizard Limo
I knew I would hear some but holy cow! I have a 6.9 engine/flywheel with the zf/5 using a springed friction disc. Question: could this be making more noise than other smf's because the flywheel weights 23lbs less? I am thinking so but curious if there is anyone else out there with this combo? I am only using atf for now...will consider other options to reduce noise and protect the fragile zf.
My t19 had some rollover when grunting hard at about 700rpm. But this one grunts all the way up to 1200 and seems a bit louder. I know there has been many posts about rollover but anyone have the 6.9 flywheel with a zf? Didn't the '87 6.9 have a solid fly with the zf5?
