well obviously when I say 16" tires I don't actually mean the wheel size. lol
The tires say 285 r 16
they're nothing special .........just plain 285 r 16 radials.
Actually, you do!
The wheel size is 16 inch, but the tires could be anywhere from 30 to 40 inches tall, maybe more. A 30 inch tires and a 34 inch tire would be like dropping at least one gear size, possibly two! The height of the tire is the important thing here! I guarantee you don't have a 16 inch tall tire, that's about knee high!
The aspect ratio 265/75-R16 breaks down as such:
265 is the tread width (265 MM)
75 is the aspect ratio (75% of the tread width)
R says it's a radial
16 is the wheel size
So a 265/55-R16 is going to be much different in tire height than a 265/85-R16, which in turn will greatly affect the gear ratio to RPM calculations.
Might I suggest you go to
Randy's Ring and Pinion and look at the tire calculators.
