gas to diesel cluster change
3day240sx
Millington/Tn
I have a truck with a rusted out cab. I need to changed the cab and have other cabs to use but they are gasoline truck cabs. Will a diesel gauge cluster plug into the harness of a gas truck? Thanks
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
They're the same except for the tach. The tach has to be for a diesel. Oh, the fuel gauge will say UNLEADED, which may cause some grief if you let someone else drive it and they use gas instead of diesel...
CESMITH
1986F250 6.9
New Springfield Ohio
I pulled the complete harnes and dash out of diesel cab and put it in a gas cab . they were boath 86s the onyl problem I had was the gas cab had AC and the Diesel had HO heater, the holes were difrent in the fire wall. but even if you dont it would only take 4 wires to run the diesel;Sweet
3day240sx
Millington/Tn
Which 4 wires. I am thinking I am going to change from a 93 3/4 ton diesel to 89 1/2 ton gas. Got both whole trucks.
3day240sx
Millington/Tn
I am going to start over because I think I have confused everyone. I have a 93 f250 diesel that needs a cab. I have a 89 f150 that has no drivetrain. I want to change the cabs. I will get another cluster to go in the 89. I want to know if I can just plug the dash harness into the new cluster and everything will work. I plan to re wire everything at the chassis fire wall plug next to the PCM plug. Thanks for the help and sorry for the headache.
jorge140
