Gas caps
The FNG
NOT a Powerstroke!
Goldendale, WA
Don't forget to put them back on after you fill up!
Josh Carmack
Ripley, TN
that looks like my truck every time I fill up, seems i'm too cheap to buy an automatic nozzle, and can't ever be at the pump the exact moment it runs over.
The FNG
NOT a Powerstroke!
Goldendale, WA
You should see the oil streaks on the corners on my way into work. I thin one is over 100 ft long...
Josh Carmack
Ripley, TN
They wash away, I promise. On my little benz's it's easy to get the cap on wrong. The fuel tank is up in the trunk, higher than most vehicles, and when the tank is more than 3/4 full and the cap is not on correctly it will dump gobs of fuel out on every corner. I left a large wide streak from my barn all the way past the corner at my house, couple hundred yards long. It was 90% WMO. can't even tell it happened 9 months later.
idi_Marty
Tollesboro, Ky
Just saw this lol, we had a guy at work drive away from the pump with the stations pump still hanging over the winter.... hence his name is now Nozzle.
FarmerFrank
Blairsville, Pa
That why I like my flat black bed... Evey time I fill up I just put the hose and ball valve in and go back into the shop. When I see it start to spill its time to shut it off.
The FNG
NOT a Powerstroke!
Goldendale, WA
And just to brag a little...400 gallons I just got on CL!
m2rtin
