NCheek
Howdy
I'm in the middle of properly redoing some wiring on my truck. The PO had a wire spliced (rather poorly I might add) to the 12v ignition on that energizes the FSS.
In my search for a better power-source to trigger a relay, I found a 15A fuse labeled "Accessory" in the fuse panel that appears to have nothing going to it.
My question is how do you remove the bars (for lack of a better term) to which the fuses attach from the plastic case?
If this fuse is already being used, I can use another blank terminal, but I still need to remove the bars.
I would much rather do it this way than use on of those in-line type splices.
