Still never answered what you are using to time...
May be if an adjustable light it's outta whack?
Try some TIMING TAPE and check it. I think I did a tech 101 on timing tape I dunno... shows how where etc what size to use and all the math involved.
Then set yer timing light to zero and read right off harmonic..and tape. see what it says...
If using a timing light you DON"T use a 20 deg offset as the mark for 0 or TDC is different than the MAG probe location for the Meter mag pick up point...that's why you offset the meter cause the probe is 20 deg off from the TDC point...
Just sayin...
Just sayin...
