hairyboxnoogle
Ok, so i got into some trouble, and as it turns out im not going to be driving my truck for a while... legally at any rate. So i started thinkin of things i could do to it since i dont need to drive it. After talking to a dodge buddy of mine i can get an HX35 for pretty much nuthin. So now im thinking i can play around with fitting it on there and getting it working.
Parts list right off the top of my head:
turbo, manifold flanges, turbo hotside flange, weld elbows and pipe, 7.3 SD intercooler, aluminum tubing, silicone boots, pyro, oil supply /return line, cone air filter.
Im sure i missed a bunch of important stuff, but realistically it should be fun, kill time, keep me from driving my truck, and be a learning experience.
Now speaking of experience, i have none with turbos so here is what i propose. On my stock NA 7.3 with 280k, no studs, no new head gaskets, and stock IP / injectors, will the HX35 do what i need or should i look into the hx40? I can get either the 40 is $50 more. I dont want to do anything to the engine besides turbo it, and not blow it up. Figuring on 15lbs of boost, might see 17. As far as i know the 35 will do all this just fine long before egts and lack of fuel come into the equation.
I chose this turbo on price and availability alone, i have to run custom manifolds and up /down pipes anyway in my truck so i figured what the hell.
So lemme hear all the cheers, advice, booing, flaming, ideas or anything else y'all want to throw my way.
