GRU
fear the chicken legs
ok i need help from all you cummins swap guys. whats everyone doing for their alternator situation? i know some of you retained a ford alternator. im trying to retain the dodge alternator since its already bolted in nicely. in the dodge the voltage is regulated by the computer. but its a well documented "mod" to wire in a normal regulator if the one in the computer goes bad. really as i understand it all thats involved is taking the two field wires in the ford harness and bolting them on the two fields on the dodge. but this isnt working in my case. im getting absolutely no voltage at all. ive tried a million different things, even a new alternator. im using a known working regulator from my other truck. i am getting voltage to the regulator from the key switch even though the charge light will not light. what am i missing??
