Fuel tank woes
chillman88
Central NY
I know you rustbelt guys just weld a rod to the bed bolt head and go to town right??!!!
Or socket and long extension bend over side to side and snap ole rusty nutz clean off.
I just pulled the bed of the crawler for its first time, with a 3\8" ratchet;Poke but it's only an 83.
Not gonna lie, I was considering welding a rod to the heads of the bolt pairs tying them together lol!
Clb
Another old truck
nannyfornia
Makes the rattle gun Happy.
Screw evil white chitt(sno)
Alwaysreadyrob
2002 7.3 POWERSTROKE 4x4
OAKHURST CA
10-4 on the plastic line. The rear tank is empty and the front tank is accessible for me to take the line off in just a matter of a couple minutes.
I would imagine I could crimp the hose at the lift pump.
Didn't realize that valve was 300 bucks! I would rather have a factory valve as opposed to retrofitting something else.
Try silly putty
Bart F-350
FRANCE
gassers of the same vintage use the same FSV's as the diesels.
Are they??? the diesel (normally) has a fuel return that is switched together with the fuel pull off, so that the fuel return drops back in the same tank that you're pulling off.
Tristan
Federal Way, WA
i modded a truck to run the "Mulochico fuel tank mod"
he draws off the front, returns to the rear and interconnects from the rear to the front.
i done it in a way where I can undo what has been done. if your FSV is jammed the same direction, it's something to consider.
oh yea, I fixed a broken showerhead while I was in there too.
the first two pics illustrate the "bridge" line from the rear to the front. I still need to cork off the disconnected draw line from the rear and the return line in the front.
Towcat,
Is this setup still working for you?
Does it seem to gravity feed from the rear to the front even drawing from the top (normal location)?
