Fuel tank pickup/sender wiring?
ny.wolcott
worcester, ny
I have a 1989 F350 7.3 diesel P/U with dual fuel tanks.
When on the rear tank the gauge always reads full.
When on the front tank the gauge reads full until the last 5 gallons or so, and then falls quickly.
Anyone have an idea what might cause this? Could there be an "open" in the wiring to the rear tank sending unit that causes the rear guage to always read full and a voltage variation to the front guage that could result in this?
Thanks in advance.
swuchase1
La Mesa, ca.
I have the same problem with my 88 f-250 and the battery light is on. i think its a ground short??? do you see any change when you step on the brake? if/when i figure it out i will get back to you.
ny.wolcott
worcester, ny
There are no other symptoms in my case. Brake light is off and nothing weird when brakes applied.
Yours does sound like a grounding problem somewhere.
allczns
me too...
...both gauges are pegged past full until the last few gallons, then dive to empty. I drive by the odometer.
No answers, only questions...
cheers,
Nicp
WAR PIG
decatur AR
I have same thing wrong with my 88 ford i posted a therd and basically came to the conclusion it my sending units you can check both them and i had buddy who had wholes in his floats to so there to place i would look first
w4dsb
loganville ga
my front one is always empty even with fuel running out the neck! I suspect my float has crapped out
lpennock
Chandler, AZ
Your float is probally shot. Depending on the style of float you need you can just buy a replacement. My 92 was able to use the float from a old Bronco and it was a direct replacement. The float can be bought for about $5 from bronco graveyard so that you don't need to buy a complete sending unit
http://broncograveyard.com/bronco/i-10224-brass-sending-unit-float-66-77.html
FORDMAN41291
Herndon, KY
is there anyway to get my Gas Gauge needle to quit FLOATING!!!? I mean its worse than that POS Chevrolet thats sitting in my back yard. sometimes is floats really bad and other times it doesnt. it usually get bad when im betweem a half and 1/4 tank of gas. when i park on a hil or something the gauge goes back to normal after the float drained out for a while or so......
I-HFreak
spencer,tn
so the floats can be replaced on a 1986 IDI? with dual tanks both dont work and exactly the same
FORDMAN41291
Herndon, KY
I know I might just either need a new float or sending unit in my 94 F150 300 I6... anyone have one they could throw my way??
lotzagoodstuff
Carmel, IN
Floats should be available (changed both of mine, albeit its newer), not really that hard to change on a saddle tank as you should be able to sneak it out if you are patient. Rear tanks are definitely harder, you have to drop the tank in most cases. Have a look at the pickup tube while you have the sending unit out.
FORDMAN41291
Herndon, KY
what i dont understand is why Ford didnt put a pump in the tank itself but had a manual lift pump???
lpennock
Chandler, AZ
Actually consider that a good thing. When the stock lift pump goes out it is pretty easy to replace. If you have a in tank pump you have to drop the tank to change it. With the stock IDI pump you can always bypass it and put an inline electric pump without much effort. I need a better lift pump on my Cummins and I need to rip the in tank pump out make a adapter to pickup the fuel and then add a hi performance inline lift pump. All because the stock lift pump can't keep up under hard acceleration. Also have you looked at the replacement cost on a intank pump compared to what the IDI pump costs?
Lance
