Fuel Tank pick-ups
160k87F250
not rocket science
York, PA
Any other options besides the dealer for a fuel tank pick up for the rear tank of my F350. Even with my employee discount it's still $190.00.
John
12clip
Warren MB
I was in the same predicament recently. I had to bite the bullet and order the Ford one. It was about $290 employee cost here in Canada so consider yourself lucky.
The listing should tell you that you need a connector kit to fit to your truck as the sender is for a 96 and up I think. The conector kit was another $50 or so, but I just used a harness side O2 connector and cut off one locating tab.
160k87F250
not rocket science
York, PA
Autozone only has a complete fuel tank assembly, which includes the sender and new straps. Not bad for 319, but that still cost more than 190.
idiabuse
Princeton Fl
I had to fix mine too, permanently!
still works great! I did both tanks, and in case of sabotage I can drain both tanks in 5 minutes
Javier
idiabuse
Princeton Fl
Never have to worry about fuel delivery, even if I lose my fuel pump "Holley Blue" the injection pump will pull fuel and keep me going down the road.
No more rough running, stalling, sputtering, cursing, punching my truck anymore.
Javier
