LCAM-01XA
Mike, your fuel pickups are damaged inside the tanks - it's a fairly common issue, the plastic "shower head" part falls off the steel line, so now instead of sucking fuel in from the very bottom of the tank you can only go down to half a tank before the steel line sucks air in. The solution would be to pull the senders off the tanks and extend the 3/8" line with rubber hose till it reaches the sump at the bottom of the tank, some people install a brass T-ee fitting at the hose's end to make sure it don't suck itself against the tank bottom.
