They're not too bed to remove, but don't forget to have some friends around to help with this unless you have another way to pick up the bed.
when I removed my bed, I used a Cherry Picker and HF Straps. I first had the 2 straps connected diagonally to each corner, but it wouldn`t lift it up. Then put one connected under ea fender lip and she pulled straight up.
I have one of those tire mounts bolted to the L/F corner.
That was just enough weight to not let her come up straight till I put my tool bag on the opposite corner to balance her. Then set the bed on some saw Horses.
When I put it back on, the HF Straps made me a bit nervous, so I picked one of the metal bed lifters.
Here is an example, too pricy check around for the best price or if you are a welder you can make one.
https://www.redlinestands.com/catal...-327_345_530/innovative-truck-bed-lift-p-1422
This one has the fancy padded pads etc.....
I recommend to put a 2 x 4 piece of wood under the bed lip to spread the lift point.
here is a picture I found similar to what I did.
Goat.
