PapaJammie
Hello all,
bought my 1988 F-350 Crew Cab with ATS turbo kit from my father in law about a year ago, and have run into a few significant problems since then. the C-6 transmission failed on the truck about a week after i had bought it, and the truck has been sitting in my driveway since then while i gather the parts for a ZF-5 swap. (all i have left to find is the pedals at this point) Anyway, ive noticed that the fuel gauge stays above full all the time no matter which position the tank selector switch is in, (i know the tanks are not full) and i can not hear the valve switching when i move the switch, so i'm going to assume that the valve is broken. i have no idea which tank it is pulling fuel from, and i have no way of knowing my fuel level. My question is- is there any way to delete the fuel selector valve and somehow hook the tanks together so that I could essentially "combine" them into one tank? i have seen the manual selector valves in the tech section but i do not like the way that is set up. i could always just run one bigger fuel tank, but im trying to spend as little money as possible. also, does anyone know why my gauge would be reading full all the time? is that a problem with the selector valve or with the sending units?
thank you
thank you
