Fuel Pump Block Off Plate
frankenwrench
overkill is under rated!
Weatherford tx
I believe so. Don't remember part number off hand, but I grabbed one off the performance wall of orily for a chebby to do mine. Looked like that one. Someone will correct me if I'm incorrect on that being the correct part number
Clb
Another old truck
nannyfornia
There is a pn in the tech section with the facett (fail, read up first)pump swap on here...
hope you did some research on e pump models!
catbird7
PA
I think it's simply a big block Chevy block-off plate.
hesutton
The Anti-Anderson
Bowling Green, KY
Yes that will work. I've done this a few times and used the same block off plate for a BBC. Never needed any modifications. They should just bolt right in place of the mechanical lift pump.
Heath
SkipBurney
Statesboro Georgia
I used a BB Chevrolet plate and the casting flange on the block held it off so I had to grind mine just a little for it to clear
BrianX128
Pittsburgh
There are for sure two parts numbers and the one will leak some if you don't grind a small part off. I've had both, they are listed on here somewhere but I can't find it. It's an easy fix if you get the wrong one though, just let the truck idle for 5 minutes and find out before you go driving.
mblaney
Ottawa/Ont/Canada
I made my own (too lazy to go to the store and buy one :rolleyes:). Just buy one and match it up with the profile of your old fuel pump. Grind away if needed.
typ4
Newberg,OR
