rpm's will drop momentarily while driving down the road.if I keep steady pedal pressure trying to keep same rpm it will drop to an idle speed & then pick back up again. It will do this in park also, trying to keep steady rpm it will drop & then pick up again.but I see no codes that are associated.I have pulled egr & cleaned.It didn't look clogged.And I also cleaned tube leading to EBP sensor.
