So I have a really strange problem. My fuel pressure at the filter head drops as the truck warms up. New fuel lines. New fuel filter. New facet 40222 pump.
When I cold start it, it's at 8-9. By the time it's at operating temperature it's 0.
I unscrewed the fuel caps so I know it's not a venting issue.
I switched tanks. Doesn't seem to matter.
I don't think there is any correlation to run time but I'm not sure.
There seems to be a correlation to temperature but I'm not sure.
This screams either lift pump or air leak to me but I don't know.
There's no way this is an IP issue right? It seems like once I mess with things to get a little fuel pressure it will start again.
First thing I'm going to do is add a section of soft line between the lift pump and the supply line in case the fitting is working loose. I found that fitting loose before but it did not seem loose this time. Not sure where I'm going from there.
