Okay boys let me give the rundown. Went to Napa and of course they could order me the strainer, but it would be a week before they could get it so I went to the back with them (since I used to work there) and browsed around looking at the different strainers they had. I found one I had to modify a bit but it worked the part number I used was Line code: NFP Part #STS-136. Here are the pics of the newly modified pickup.
All said and done with the three inch 3/8 fuel line, two hose clamps and the strainer cost me $30.36. I placed the assembly in the tank and it sits on the bottom as is should, so I should be able to get everydrop out this sucker now HE HE HE HE. The strainer was a little bigger than the hose so I sqrayed some white lithium grease in the hose and it slid on like a champ. Dave or M.L.S.C., if you want you can save these pics to for a reference so it may help somebody else that may want to do the same thing. I haven't installed it back in the tank yet because I noticed the tank had a teeny bit of rust where the straps run (not enough to really worry about) so right now I'm waiting for the nice coating of rubberized undercoating spray I just applied to cover the rust and prevent any more, and to protect rubbing issues. I'll let you guys know how well it works.
