justinray
Contributor
It's just 8 lines, and 8 injectors, takes an extra 20 mins, and gives you something to do while the oil is draining.
With my timing set to the same degree...I got all the above except slightly worse mpgI can only report anecdotally but after Mel set mine to 9.5 (from about 7.5 or so) I noticed more noise, more snap in off-idle acceleration performance, and a slight uptick in mpg. I can't give you a number yet, but I'm tracking it. I drive this truck so seldom these days that it takes a while to generate averages. If I was forced to guesstimate a number, I'd say it's under 1 mpg... which makes it more or less within a margin for error and will take a looooong time to average out a good number, if I ever can.
I put my 40s back on and it seems to be pulling better up hills but I still have quite a bit of throttle slug. It I give it too much throttle it acts like it's starving for fuel. Still getting a lot of black smoke too, hard to tell if it was happening with the fuel starvation since it happened tonight. Hopefully ordering a ferret soon.
Just blew a ujoint and tore the ears off both axlehshafts so I'll add that to the list.
This is true, if finances allow, I find it best to have injectors pop tested every other oil change, and reset timing. It really isn't that big of a deal, and I find that IP's and Injectors last longer, and I get much better mileage, so it pays for itself in many ways over time.
For some people that is new injectors every month. Sorry but on a 6.5L no one would ever do that, I takes 2-4hr to get to the injectors normally.
I guess if we changed them once a month then our turbo wouldnt be siezed to our manifold as bad and pulling our inner fender wouldnt be so awkward. Practice makes perfect.
Ive never pulled turbo or anything for injectors, but I've never worked on a 6.5
i believe she's starving for more air,not fuel.
Now that I think about it, if I get to a certain point in the pedal I get fuel starvation and no smoke at all. When I back off I get a big increase in power and a little bit of smoke. I think it's when I go past the dead spot it just dumps fuel like crazy and blows black smoke. There might be a little bit of excess fuel dumping right before the "nice" spot when I start to back off the pedal as well.
IMO pulling injectors every other oil change seems like a waste. They are cheap enough to just replace when the time comes. I certainly don't have the time to pull them that often when there are plenty of other things on my to do list.
