Fuel lvl gauge help
Bootzz
Louisiana
I took out my front tank since it was giving me problems. Ima do away with my valve and just run straight from my tank. What color wires on the bottom of my valve are the ones to tell my fuel level so I can hook up my after market full level gage?
The sending unit wire coming from the rear tank is yellow/lightblue stripe. Be careful, the wire for the front is darkblue/yellow stripe. The yellow/white stripe wire goes to the fuel gauge. So if you want to run the rear tank only, tie the yellow/lightblue to the yellow/white wire.
Bootzz
Louisiana
Ok thanks! And the yellow/white stripe will go to my aftermarket gauge?
The yellow/white goes to the factory gauge in the cluster. If you want to interecept it somewhere along the way and re-direct it to your new gauge you can. Or you can just run a new wire from the frame area up to your new gauge.
Bootzz
Louisiana
I'm confused now
What do you mean from the frame area??
I don't have a factory cluster anymore
It's all aftermarket
Cv axle
