Fuel Line Recommendations
mankypro
Learning Slowly...
Boulder County, Colorado
I'm about to drop my rear tank and drop in an Arctic Fox and install a inline Vegtherm Mega as well.
I'm looking to replace all my rubber fuel lines with high quality Viton line - including the return lines at the same time.
Is there a good place to buy a spool of this stuff from? And how much hose do I need? Is it 3/8" ID?
hheynow
the misanthrope
SF Bay Area
rkpatt
ATL , GA
Sometimes the auto parts stores will give you break on a 25 foot roll . Also check with this ebay seller "supermall " - [email protected] . Consider splicing in SAR30R7 hose or aluminum tubing on the long easy to replace runs under the truck. Also look at replacing the stock sending unit too with a Centroid or Isspro sending unit . BTW, I have found SAE30R7 hose to be fine for WVO for but agree that using the heavier duty Viton - SAE30R9 hose at least coming from the the rear tank to an accessible location is good idea .
Look in the parts bin. We have McMaster Carr part numbers for all that stuff.
LOL Nobody can ever find that for some reason. It's on page 2 of the tech articles.
Here
zemmeron
