Fuel Lil gauge
Bootzz
Louisiana
I'm going to hook up am aftermarket gauge in my truck. Anyone know what ohm resistance I should get for a 1992 f250 7.3?
Is it a fuel guage your asking about? Unless someone knows what resistance the sender has, you'll have to pull the sender out of the tank and measure the resistance.
gatorman21218
Ashland VA
I cant remember the ohm reading but its an oddball one. I couldnt find a gauge with the factory range so I bought an aftermarket sender as well as a new gauge.
Bootzz
Louisiana
Yes an aftermarket fuel level is what I'm talking about. Ill probably call ford and ask
mf7lakes
North Carolina
I found a spec at another forum that says: quote
"01-29-2013, 02:36 AM Report Post
I have these numbers saved in a text file, based on info posted on here and at STD over the last 10 years. I haven't verified them independently, but hopefully someone who knows for sure can corroborate or refute these
'87-'97 trucks: 22.5 ohms empty, 145 ohms full"---- unquote
maybe this helps ????
Bootzz
Louisiana
Hmm ima look at the gauges a Lil more
I don't understand how it works all that great
I don't understand the 2 diff resistances at full or empty
gatorman21218
Ashland VA
basic electrical theory is applied here. ohms law. current equals voltage divided by resistance.
When you apply voltage across a resister, it changes the amperage. So for instance if the range is 0 ohms (full) to 100 ohms (empty), then when the tank is full, it sends full amperage to the gauge therefor making it read full. at half tank (50 ohms = 50%) its giving half the current to the gauge, making the gauge read half. so on so forth....
Thats why different ohm senders do not work with different ohm gauges.
Cv axle
