rodymartin
Now Ihave fuel in the engine oil Help!!!!! I need to know what can leak into the oil from the fuel system?
sound like the manual fuel pump is adding to your oil...are you running just the manual or manual and eletric.... I did once till I had your problem,,,,,
It can come from the mechanical lift pump OR the injection pump, if you have an input shaft seal, and the weep hole is clogged (or doesn't exist as is the case with some early pumps). Best bet is to take this as an opportunity to upgrade to an electric fuel pump. Even if that doesn't fix the leak, at least it removes all doubt as to the source.
