Fuel Filter wrench?
myoder
Stupid Question, but I have a 03' GMC 2500HD D/A and have had the truck serviced at the dealer in the past, but this time I decided to do it myself and change the fuel filter... What type of fuel filter wrench do you guys use to into the tight space?
I have tried 3" -3 7/8" filter wrench but not big enough. Thanks in advance.
dieselman
I don't know the brand I have but I got it at gmdieseltech.com. Eric sells a flexible handle one that fits well in that spot.
Max Power
I just use an oil filter wrench that is the right size. Lots use a strap wrench. Good luck!
TheBac
UPS guy
Lansing, Michigan
Regular old oil filter strap wrench does the job. Fuel filter is slightly bigger than a "normal" oil filter, though.
army
Swift Current, Sask
Bought a cheap strap wrench at a farm supply - you twist it with a ratchet and a long extension from the top- works great!:D
myoder
I got a strap wrench and that did the trick... Thanks for replies!!!
Geno
Noble Ok
Be careful with the plastic W.I.F. sensor in bottom of filter it is made of platic and will break very easey
Geno
Blinky
Mission Viejo, CA
A strap wrench does it.... don't let the dealer overcharge you for someting my 11 year old does....
Tyler9828
