Fuel economy for 89' IDI. (Transmission)
I also swapped from a c6 to a zf 5 speed. No other changes and I went from 12mpg to 15mpg. And It's so much quieter going down the interstate.
Clb
Another old truck
nannyfornia
Add a brownie to that 5 gear, get more versatility to boot.
Many of the suggestions are correct but changing your rear gear ratio is another good way to change what you want.
He likely has 3.55 @icanfixall already so ....E4OD and its inherent headaches of a swap...or ZF 5SP swap or add an overdrive or brownie of some sorts....
About a $1000 dollars. Clutch, flywheel, ZF4 or 5, drive line shafts, brake clutch assembly, firewall mod. Someone else besides yourself, add another $800 to $1000. Then another $250 to $500 for Hydro brakes.
Would you happen to have a full swap parts list and brands my ZF5 arrives wednesday
Pretty straight forward....
Trans tunnel cover and shifter boots
Pedal assembly for std trams
Clutch master slave and line...year appropriate
New plug for std trams to use back up lights...
Std F350 zf crossmember a d brace
If u had a c6 likely drive shafts same length
Since a brick nose @freebird01 firewall brace so no problemo later on.
Std column if so inclined.
New pilot n throwout bearings
New.clutch and pp and flywheel.
I used all my own parts so no numbers sorry. I have a lot of used stock here.
catbird7
PA
What year is the ZF? I think 1992 and up didn't use a speedo cable rather a sensor on the rear axle. Your 89 truck has a cable. Possibly the ZF (if newer than 91) can be adapted for the cable??? Someone on here will likely know........
olsen726
