fuel and return size ?
giezy
rockwood/on/Canada
fuel and return size ? upgrade in size?
and is would it be good to use stainless and rubber line to join lines
Mine are rotted and leaking time to replce the whole lines
ah1988ford
florida
You are talking about the return lines that run imbetween the injectors right ?
I thin its a 5/16 hose id.. i think dont take my word on that I am sure someone will come along and verify that.
If you are, i think it is best to just order a injection return line kit they are easy and simple to install and if done right they will last you along time imho ... there are two members on here that sell good kits from what I have heard, Agnem and typ4.
Agnem's website is conestogadiesel.com
Typ4, you have to private message him.
giezy
rockwood/on/Canada
already did those talking about the lines from the tank to the switch and then to the lift pump is it any advanage to up the fead line?
sle2115
NRA LIFE MEMBER
Southeast Ohio
3/8 feed and 5/16 return, I used braided stainless from about 1 foot out of the tanks on...been on there for years with my Carter electric pump and Permacool inline filter.
Alleycat
