FSV bypass
93IDITURBOPOWER
93IDITURBOPOWER
Colfax, CA, USA
Hi again guys. I'm planning on bypassing my back tank on my truck becaue it is sucking air, and I don't need another tank. So by looking under the truck I would imagine you connect the return line from the engine and front tank together and the pickup lines from engine to front tank together?? If not please correct me.. Also, do I cap the lines coming from the back line or what? Leave them hooked up to the FSV? I'm a rookie sometimes l, so help is much appreciated. Thanks guys. And will my gauge stay working also? Or is that another thing I have to do?
Thewespaul
Bulverde, Texas
I would just remove fsv and use a rubber hose in its place. Just connect the front tank to the engine side fuel line. Fuel gauge stays the same.
