Clutch bypass and cruise
Rondo
Colorado
My wife has problems pushing the clutch in enough to start the truck. I am thinking about getting the clutch bypass plug. My questions are will this doable my cruise? If it will, is it possible to open it up and short two connectors to get the cruise working again? Which two connectors to short. I know the cruise will not disengage if I do this. If I just short 2 wires going to the current switch, which ones will enable it to start without the clutch?
Kdo58
Puyallup washington
Disconnect the wire plug connector at the switch on the clutch rod, and plug in a blade fuse, no idea about cruise controll.
Austin86250
idaho
My truck was an auto and did a manual swap so it had the factory clutch switch bypass and cruise worked fine I’ll see if I can find a picture
lewisstevey7
