razorback
For Sale 1987 f-350 dually Auto c-6 4 door long bed
good
brand new carpet
bled/flushed brakes
flushed coolant
flushed steering fluid
new brake pads and shoes rotors on front
new shocks all around
new power steering pump
4g 130 amp alternator
new interior carpet
new turbo IP
new injectors with new o rings/caps and fuel lines
new vacuum pump
new glow plugs
new ebrake cables
new trans filter and fluid
6 new tires, 4 put on 2 sitting in garage
custom turbo setup using gt45 with 3.5 inch exhaust,
headlight harness, pulls power from batteries not switch
new fog lights
new/rebuilt water seperator
2 new 850cca batteries
cd player
new fuel selecter valve
bent brush guard will come with it
10k bumper on back
side step rails
aftermarket grill
visor with running lights
electric fuel pump for fuel and as oil scavenge pump for turbo
solid oak head console
4 door truck with long bed
actually started using only 1 battery few days ago, starts right off good motor compression
new trans filter with correct ford fluid
changed rearend fluid
bad
ac does not work, small fire melted wiring found replacement harness, ac compressor was seized parts will come with
wobble in drivers front wheel... going to check to see if it is a bushing or something loose
fuel senders are hit and miss.. have one replacement one but need to be adjusted
paint not perfect but not horrible, some nicks/dings
seatbelt on passenger side has a tear in it,honestly no idea where it came from.
bed has holes cut above fuel senders, will be covered with a plate and sprayed over with bedliner to be sealed
tailgate works but not pretty
asking price 2k located south of branson, mo motivated to sell just taking up space do need to sell by mid november as i am going out of town week of thanksgiving.
can hear it run,will not try to start it until you get to see it, and see that it powers itself. but not insured or registered only reason driving may not be good idea
email me and i will give phone number and email address
will upload pics tonight.
good
brand new carpet
bled/flushed brakes
flushed coolant
new interior carpet
new turbo IP
new vacuum pump
new glow plugs
new ebrake cables
new fog lights
cd player
10k bumper on back
side step rails
aftermarket grill
bad
