I have a 1986 Ford Truck that I converted to a Cummins. Truck started as a F250 but I bought a '96 F350 and completely rebuilt the rears and suspension and put them on the '86. I also added a posi unit to the rear. Engine is a 12 valve with a 913 pump, 215 horse injectors, H1C/E hybrid turbo, large F700 intercooler, and F700 radiator. Also put stainless brake lines in the truck. Truck has custom electric fan setup. Also I installed Egt, air cleaner, boost, engine temp, voltage, oil pressure, trans temp, transfer temp, and rear end temp gauges. Rear tank was replaced with a high capacity Bronco unit with a bottom pickup sump with a tank drain and settlement area. I have a huge amount of time and money in this truck, but I need to get a four door. I have no idea what the truck is worth, but I would like to get $10,000 for it. To me that feels like too little, but I know you can't get everything back. Please let me know if that price is unrealistic. Will try to post pics when I figure out how to do so on this forum.
