Front Disc Brake Hub and Rotor
1. Note: When raising the vehicle, make sure the hoist lift points do not rest on the caliper pins.
Raise the front of the vehicle and install safety stands.
2. Remove the wheel (1007) and tire assembly.
3. Remove both anchor bracket bolts. Examine both bolts for damage.
4. Remove the disc brake caliper and anchor bracket assembly from the front disc brake hub and rotor (1102) and suspend it out of the way with wire.
5. Remove the hub grease cap (1131), cotter pin, and nut retainer.
6. CAUTION: With the spindle nut removed, the front disc brake hub and rotor can slide off the front wheel spindle (3105).
Note: On F-Super Duty, the front disc brake rotor (1125) can be separated from the wheel hub (1104). Refer to the illustration in this section.
Remove the spindle nut, front wheel outer bearing retainer washer (1195), the outer front wheel bearing (1216) and the front disc brake hub and rotor.
7. Check the condition of the front disc brake hub and rotor. Refer to «Section 06-00».
8. Remove the wheel hub grease seal and the inner bearing cone and roller (1201). Discard the seal.
Installation
1. If installing a new front disc brake hub and rotor, remove the protective coating or any dirt or grease deposits with degreaser. On F-Super Duty vehicles, the machine screw threads must be coated with a suitable adhesive before attaching the front disc brake rotor to the wheel hub. Tighten screws to 100-120 N-m (74-89 lb-ft).
2. Thoroughly clean the bearing cone and rollers. Inspect for damage or wear. Refer to «Section 04-00» for front wheel bearing adjustment. Replace if necessary.
3. Pack the front wheel bearing and bearing cone and roller with a lithium-base grease such as Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B.
4. Install the inner bearing cone and roller. Refer to «Section 04-01A» for 4x2 or «Section 05-03C» for 4x4 procedures.
5. Install the front disc brake hub and rotor on the front wheel spindle.
6. Install the outer front wheel bearing, front wheel outer bearing retainer washer and spindle nut.
7. Adjust bearing end play. Refer to «Section 04-01A».
8. Install the disc brake caliper and anchor bracket assembly by installing two anchor bracket bolts. Tighten both bolts to 119-259 N-m (141-190 lb-ft).
9. Install the wheel and tire assembly. Tighten the lug nuts (1012) to the proper torque. Refer to «Specifications» at the end of this section.
10. Lower the vehicle. Check brakes for proper operation.
FROM THE FORD MANUAL
