jhenegh
Truck Still Earns its Keep
So the Dana 60 that lives under my F250 has given me almost 20k trouble free miles and 3 winters of snowplowing dependability, and since I literally did nothing to it before I installed it in 2013, it was time to finally give it some love. This became obvious when I went and changed the gear lube this fall and it promptly started coming back out the drivers side axle tube. Knowing that getting in there required some disassembly, I started making plans.
I took some pictures along the way in case they are helpful to others. Probably not "tech worthy", but just what I was able to document with dirty hands and working alone 95% of the time.
I'll put all the part numbers for what I used at the end.
I started with the leaf spring bushings. This isn't immediately related to the $10 seal that started this expedition, but I wanted to be thorough.
With a press, this isn't a bad job at all. The used F350 springs were installed with the axle in 2013 with new bolts but with no anti-sieze, and they had rusted in place solid. I used the ball joint press to get them started moving and then a big punch once they were flush. Tougher than I expected.
The bushings weren't terrible, but it was time
Out with the old! The new poly bushings press in with just 2 hands and their assembly grease so no pics there! I reinstalled Energy Suspension poly bushings. They admittedly probably provide a firmer/harsher ride, but I like the poly products so I used them.
I used all new hardware with it going back together again. 9/16" bolts were harder to find than I expected.
Next post....
Next post....
