Front End Popping Noise
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
my midship bearing is loose. don't know if that is the issue or not but it has seen better days. i pushed on the front fenders again, only harder this time, and it seems like i got a little clunk from somewhere in the rear of the truck. all the sway bars are tight, shocks are tight, leaf spring u-bolts are tight. i did go back and recheck the radius arm nuts and the axle pivot bolts and they are tight.
94f450sd
somewhere,ma
i checked the fender bolts and found some to be a little loose.
these were a touch loose on both sides.
these were also loose on both sides.
The second picture are the bolts im talking about.also a good idea to check the very bottom bolt at the rocker.
'94IDITurbo7.3
HAMMER DOWN!
i think i might have solved the issue by tightening up the bolts that i have pictured. i didn't notice any popping today when i went to school. tomorrow at work will be the real test though since the terrain i drive over there had the truck really popping the past couple weeks.
bob123456789
Staff online
