'94IDITurbo7.3
HAMMER DOWN!
Ever since i hit a deer with my truck a few weeks back i am getting a clunking/popping noise coming from the front end. it only happens when turning at low speeds over un-even ground or going straight over un-even ground at low speeds.
Everything except for coil springs and ball joints are new on the front. radius arm bushings, axle pivot bushings, all the tie rods, sway bar link bushings & bar to frame bushings, new shocks. Cab mounts are still solid(probly sagging a touch, but solid none the less). the pass side ball joints are starting to get a touch loose, but they don't seem to be loose enough to cause this much noise(it literally sounds like the front end is going to fall off i can "feel" the popping in the floor of the cab). As per the Ford TSB on this issue, i inspected the rivets that hold the axle pivot drop brackets to the front x-member and they are all good and solid. Lug nuts are tight as well.
I really don't know where to look now. Guy at school said the coil springs could be weak causing the axles to hit the bump stops. i'm not sure about that though as that would probly be more like a dull thud rather than a popping noise. i also noticed that the pass side of the cab is sitting lower than the drivers side. ground to bottom of rocker panel: driver's side - 19"........pass side - 18.5". there is a sticky on this over on powerstrokearmy.com but no solutions to it. it seems to be a VERY common thing with the f-250's, 4x4 or 2wd doesn't matter, so that tells me that it must be something in the way the front ends are hooked up the frame, ie. something with the TTB. but then again other than the axle pivots, the 4x4 and 2wd F-250's don't have anything in common for the front suspension so........
Any help will be greatly appreciated!
