I can't get a answer at Ford go figure. I need some help on how to change the front wheel bearings on a 03 4x4.The last time i needed help i had to come here also . Thanks Jim
half ton or 3/4 ton? this is the cummins thread btw. but im pretty sure on either variation you take your brakes off and on the back side of the hub should be like 3 or 4 bolts and the hub/bearing assembly just unbolts. they are a sealed non servicable bearing.
