ford frustrated
derric
oakman/alabama
ok thank u very much, it should make things easier to figure out which one is the problem, I took the starter off once and had autozone check it, which it works but may not be turning fast enough for that engine, I love these trucks but so much to check when they get older and hadn't been took care of in the past plus im no genius when it comes to diesels
Kheg
North Dakota
Admittedly I may be way of base here but, when I first got my truck it was doing the same thing. The culprit was bad glow plug wiring causing the glow plugs to short cycle and not heat. Just a thought....
Clb
Another old truck
nannyfornia
The hard line from the tank on my 93 is 1/4"(6.35mm)
But looks like the hose is 3/8? To pump.
Won't know for sure till tomorrow.
Rot Box
Northern Utah
Lewiston
If it hasn't been mentioned already I'd recommend rebuilding the fuel filter head. Given the age it's probably due. It is pretty simple to do once it is off the truck. Mine had a bad check valve (it's inside the little brass nipple---the one with a 5/16" hose on it that goes from the head to the injector) that for whatever reason was letting fuel drain out and causing hard cold starts. Hope this helps,
Andrew
texcl
W. of Cavalier, ND
I would start by running fuel straight from a clean jar into the filter and slowly move back from there to find where the air intrusion is.
Andrew
To be more precise, this is what your referring to.
derric
oakman/alabama
ive replaced the starter now so it turns over faster, ive bought a glow pliug controller which I haven't installed yet, I replaced the rubber hose at the lift pump, I by-passed the fuel switchover valve and only run the front tank and put a checkvalve inline on the fuel supply line and it still will almost run both batteries down cranking it HELP!!!!!!!!!!!!!!!!!
are you getting smoke?
help us, help you and throw that controller on.
Bradz
